XX1 derailleur adjustment
Printable View
  • 12-31-2012
    mazafakka
    I'm trying to setup my XX1 rear derailleur, and the limit screws don't seem to actually be adjusting the horizontal position of the cage.... or really doing anything at all, for that matter. At the moment, it's adjusted too far inboard in the 42T, and I can't get it to move inward. I'm sure I'm just doing something completely wrong, but this seems pretty straightforward....
    Any input from someone who's already done this?
  • 12-31-2012
    muzzanic
    Are you sure you are using the right screws, It's a very easy job ?
  • 12-31-2012
    mazafakka
    I got it - yes I was using the right screws, but I had the cable tension too high. I basically just went back and started the setup process over from the beginning and everything was fine.
  • 12-31-2012
    Mr.Magura
    I was thinking exactly the same.
    Take a close look at the internals of you derailleur, and make sure you understand what's going on.
    Magura :)
  • 12-31-2012
    muzzanic
    I do the 1st setup with the screws before I put a cable anywhere near it.
  • 01-03-2013
    rcjonessnp175
    Ok I just installed xx1 on my 2012 stumpy evo expert. I have a problem, when I'm in the 10 tooth ring in the back and back pedal the chain skips up to the next gear and jams up abit. Anybody have this issue and is it a rear derailure adjustment?
    Played with the limit screws and b screw but have not eliminated that skip. It's the only gear that does it and shifts perfectly otherwise. Thanks for any input
  • 01-12-2013
    sakucee
    did you notice this in RD adjustment guide:
    "Align the center of the upper guide pulley with the outboard edge of the smallest cog"
  • 09-16-2013
    HDTVdevil
    Just to be sure I'm doing this right ... aligning the pulley and tensioning the cable is done with or without the chain. Already did both ways and keep having trouble with 42t cog.
  • 11-14-2013
    ban
    how loose does the cable have to be in the 10t cog? does it have to have any tension or not? Sram XX1 manual is not helpful at all
  • 11-14-2013
    muzzanic
    With mine in 10t cog, It rests more on the travel stop than the cable.
  • 11-14-2013
    ban
    okay, many thanks, I was having some shifting problems and I'm starting from scratch....
  • 11-14-2013
    The Squeaky Wheel
    Cable tension is irrelevant. The RD limit screws set the proper alignment in the biggest & smallest cogs. Cable tension is then used to fine tune shifting between gears.
    Set the limit screws with chain tension
  • 02-09-2014
    ban
    Well my adjusting problems with my XX1 keep annoying me....Last week I replaced the chain and cable housing as it didn't shift as smooth as supposed....after replacing that, and some adjusting, everything seemed to be fine again...But the first ride before that, I snapped the hanger...I "think" the rear der. didn't hit anything but of course it's difficult to say....the hanger just snapped, I wasn't even pedaling hard, I was starting to go down...Well, I replaced the hanger and all my adjusting problems started again....I couldn't make the damn thing to shift properly...When it seems to shift fine, it makes noise in one specific sprocket (which I checked and rechecked and seems to be fine...) if I give more tension to the cable, the noise goes away but it doesn't shift fine! I have mainly problems with either downshifting from the biggest sprocket or unshifting from the smallest sprocket...If I give tension, it doesn't downshift ok, and just the opposite if there is less cable tension...
    I don't know what else to check, I suspect the rear der. could be slightly bent but visually, it doesn't seem to be! I've already ordered a new rear der. to see if this is the problem but if anybody knows what else it could, it'd be great...
    just to make that clear! the chain, cable housing, hanger are new and before (when everything was new) it worked as supposed....
  • 04-30-2014
    BernoBueno
    @ban, I have the same issue. Did you solve it in the meantime?
  • 04-30-2014
    ban
    Yes I replaced the whole rear der. and everything went smooth again, seems I'd some where hit it and it was slightly bent but enough for causing bad-shifting...I didn't notice it was bent until I put it back to back with a new one....
  • 05-01-2014
    BernoBueno
    Thanks for the quick reply, ban. Which part of your rear derailleur was bent? I might have the same issue.
    Now I mounted the 34T chainring (before I had 28T) along with a longer chain, and it seemed to improve things quite a bit. However, it sometimes hangs on the smallest AND on the largest cog when shifting, but adjusting the limit screws wouldn't solve it.
    Maybe mine is bent, too...
  • 05-01-2014
    ban
    The bottom jockey wheel was slightly twisted compared to a new der. I suppose the cage was bent somewhere but I don't recall having hit anything with the der. or crashed against rocks or whatever....strange....!
  • 06-03-2014
    Phil Jones
    Chain line
    This is a common issue, and not just on XX1. when you are pedalling forwards the derailleur jockey pulley ensures the chain is 'fed' onto the correct gear in the cassette. When pedalling backwards the RD has NO effect because the chain is being 'fed' onto the top of the cassette. Generally the issue you are talking about is exacerbated by: small frames causing a very acute chain angle, or an incorrect chainline caused by the BB being spaced incorrectly. It is common for the chain to 'walk' while backpedaling either up and/or down the cassette.
    One last thing, this problem may improve as the drivetrain wears in, there are less sharp edges on the cassette and chain to 'pick up' when backpedaling.
  • 06-03-2014
    Phil Jones
    The problem you are having sounds 100% like the hanger is not aligned properly to the frame (more importantly the wheel). Many tool manufacturers make what is called a derailleur alignment gauge, basically it is a big solid bar which bolts on the hanger and shows you if it (the hanger) is parallel to the wheel. If the hanger is not parallel to the wheel by even half a degree then the derailleur will simply never work to it's full potential. I have worked as a head technician since the inception of 10 speed Mtb drivetrains, and I can say with 100% certainty that an out of alignment hanger is the most overlooked troubleshoot in existence.
    Heres some answers to the more obvious questions you probably have:
    "will the hanger be perfectly aligned on a brand new bike, even a really high end brand new bike"? Answer: Surprisingly not that often.
    "I broke my hanger, I replaced it myself, and now my shifting SUCKS!!, wtf"??
    Answer: Your old hanger was probably previously aligned by a shop that had a
    derailleur alignment gauge, when you put on your new hanger it was out
    of alignment.
    What does aligning my derailleur/hanger entail, can I do it myself?
    Aligning the derailleur literally is about bending the hanger... you really
    shouldn't do it without the alignment gauge, its a recipe for disaster
    (particularly if the hanger has a 'twist' in it). Often the hanger can
    break since aluminum won't allow much plastic deformation before a
    'brittle failure'.
    "My Lower pulley seemed to be twisted though, isn't that the problem"?
    Lower pulleys have surprisingly little affect on shifting quality; the cage
    being twisted isn't usually a suspect in trouble-shooting a poorly
    functioning RD.
  • 10-05-2014
    chris9888
    A short write up on XX1 rear derailluer adjustment:
    Two Wheels Good, Four Wheels Bad: How to Adjust SRAM XX1 Rear Derailleur
  • 10-10-2014
    chrisingrassia
    How is that possible?? How do you adjust the low limit screw with no cable installed?
    There's no way you just do it by pushing it with your hand. That's not precise enough.
  • 10-16-2014
    muzzanic
    Of course you can do it with your hand, It's a limit screw, to limit the travel.
  • 10-16-2014
    chrisingrassia
    Took my bike to a garage mechanic locally. Sure enough, he showed me how to do it with your hands. I was able to get a complete understanding now of how the limit screws, b-tension, cable tension, and barrel adjusters all work together and in what order those processes should be done in.
  • 09-03-2015
    J-Flo
    Boo on SRAM for having such crappy manuals, written in Babylonian. They leave more questions than answers. I can figure this out but it should not be difficult to write a clear set of instructions (like they do for service on RockShox forks, for example).
