XX1 1x11 drivetrain replacement- Mtbr.com
Results 1 to 11 of 11
    Well i just want to replace the rear deraileur, cassette and chain. My setup is not holding up in 1st gear anymore. I am thinking of going to X01 or alike so save some $$. Should i just start with the rear deraileur and see how it goes? If so what one should I buy?
    Reputation: Junersun's Avatar
    Jun 2014
    What's wrong with it now? You can't take the rd apart to clean it up or put a new jockey wheel in? Shift cable should refresh the setup too. You can bling out the jockeywheel with companies like enduroseal who make aftermarket jockey wheels...
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
    When I am in 1st gear it pops down to 2nd under heavy load
    Jun 2014
    This could be your cassette wearing down. It could be shifter cable not working so well anymore. Is your jockey wheels aligned with your 1st gear correctly?
    I think there are plenty of fixes you should attempt before investing in a whole new system.
    Current Bikes
    2016 YT Tues AL
    Yes it is the cassette. When it is on big gear part of the chain is not hooked one of the gear splines. What cassette should i buy
    Reputation: RS VR6's Avatar
    If its only the 42T that worn out on your XX1 cassette...you can get just the 42T from Wolf Tooth or OneUp...or you can get a whole GX cassette for around $100. The GX has a steel 42T that will last longer vs the aluminum on the X1/X01/XX1 cassettes.
    Gear 2 kinda wonky also. Where should i order gx cassette
    eBay probably has the best prices.
    Jun 2014
    If you can clear a 9t in the back I would give the e13 cassette a try. 9-46 you can basically kick eagle in the arse ;-)
    Current Bikes
    2016 YT Tues AL
    I have 1x11 shifter and deraileur. I have xd driver on a hope 2 pro. Will e13 work?
    tranqui_yanqui
    Reputation: schuster.ryan's Avatar
    Oct 2011
    If you have a Hope Hub you can use their proprietary wide range cassette
    Santa Cruz Hightower CC 29
    Santa Cruz Chameleon 27+
    Soma Double Cross
  1. 1x11 drivetrain for clydes
    By mr_bump in forum Clydesdales/Tall Riders
    Last Post: 06-12-2016, 03:04 AM
  2. Least expensive 1x11 drivetrain
    By 06HokieMTB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-22-2016, 12:16 PM
  3. 1x11 Drivetrain
    By djonesax in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2015, 07:22 PM
  4. SRAM XX1 Drivetrain 1x11
    By eurospek in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-29-2013, 08:13 PM
  5. 1x11 drivetrain and questions
    By Uncle Six Pack in forum General Discussion
    Last Post: 07-05-2012, 07:03 AM
