XX Crank Install Question- Mtbr.com
Results 1 to 3 of 3
    I like to ride my bike.
    Reputation: RideFaster's Avatar
    Dec 2004
    I just installed an XX GXP crank and the spindle shows on the drive side (there is a gap between the BB and the actual crank body). Maybe I'm just panicking, since I have a race tomorrow, but is this normal? Should it be snug against the BB seal?
    The non-drive side bolt is as tight as I can get it, the gap to the chain stays is the same on both sides and I can't push the drive side in any farther, so I think I'm all set.
    Could someone just confirm?
    I like bicycles. Bicycles make me happy. Riding them makes me even happier.
    Scott Bicycles
    Maxxis Tires
    Team Blog
    It's normal. The gap is about 3mm. The crankset won't move side to side as the non-drive bearing is sandwiched between the non-drive crankarm and a lip on the spindle. The only reason there wouldn't be a gap is if you were using an e-type front derailleur or a bottom bracket mounted chainguide. Enjoy your race...best front shifting ever!
    Dec 2004
    Thank you so much
    Scott Bicycles
    Maxxis Tires
    Team Blog
