XO shifters... angle adjustment???- Mtbr.com
Results 1 to 5 of 5
    trail addict
    Reputation: Uncle Six Pack's Avatar
    Explain a little to me about the lever angle adjustment for X0 shifters.... just got a new (used) bike and the front shifter's big paddle was catching on the little paddle.... I fiddled with it a little trailside and it is OK now, but I was want to know what else can be done. I basically loosened the pinch bolt and moved the whole lever.... but what about the allen head in the middle... does it have anything to do with free-play or lever position?
    You better just go ahead and drop that seatpost down to the reflector... the trail gets pretty rough down there.
    CHOP!
    Reputation: MartinsMental's Avatar
    Dec 2005
    Quote Originally Posted by Uncle Six Pack
    Then your paddle is bent. Either take it off and bend it back or buy a new one.
    That will disassemble your shifter in a bad way; don't do it.
    Read:
    http://www.sram.com/en/service/
    It's not where it's made but how it's made.
    trail addict
    Quote Originally Posted by MartinsMental
    I did.... and it didn't say anything about the allen in the middle.... that's why I was asking. Thanks.
    Reputation: sixate's Avatar
    Sounds like a bent paddle to me, too. I went OTB and smashed my knee into the shifter and bent my paddle, and it did the same thing. I took it off and bent it back no problem.
    trail addict
    BTW, the bent paddle makes perfect sense now that I think about it... never had that before (lucky, I guess).
    But how abut, hypothetically speaking, if I loosened that middle bolt a lot and then tightened it right back up when it didn't seem to do anything. Just suppose I did that.... any harm done?
    Please note: this hypothetical situation actually happened, before I even posted yesterday. It still works fine, but it sounds as if you know more than me what that bolt is holding in...
