Is the XO 24/36T available yet?- Mtbr.com
Results 1 to 8 of 8
    For the XO 2X10. I'm building a geared 29er and I want to use 24/36T option.
    i'm not sure it will even exist. QBP doesn't have it listed. Neither does sram's website.
    Reputation: limba's Avatar
    26-39, 28-42, I think those are your only options for double chainring XO.
    Cuánto pesa?
    Reputation: Jake Pay's Avatar
    Reputation: uzurpator's Avatar
    Dec 2005
    Sram and Shimano, fubared themselves with the moronic 80/88mm BCD on the inner chainring. Nothing smaller then 26 will fit those things.
    My guesstimates say that nothing less then 36 will fit the 120mm for sram as well.
    Cuánto pesa?
    24x36 would have to be done on the XO triple (44x32x22)....The BCD is 64/104mm...
    Dec 2005
    Ya. But in order to get XX quality shifting you will need the aligned shift gates etc, which means sourcing for a matched chainrings which... don't exist because Sram does not produce the "XX aligned" chainrings in the 104/64 format
    As I said. They fubared themselves.
    Reputation: DavidR1's Avatar
    Is there a twist shifter I can use with the new X0 double crank? Will the standard X0 shifter work?
    CyclingCentralVa.org
