• 06-25-2012
    KRob
    Too many Revelations: What's the difference between XX and RLT?
    Looking at purchasing a 2011-12 dual air 150 Revelation with 1 1/8" steertube and 20mm axle for my 2010 5 Spot. What's the difference between the miriad models. The SRAM site just confuses me more.
    Also, it seems I've read that the Dual Position is more problematic than the Dual Air. True?
  • 06-26-2012
    MartinsMental
    XX = XLoc Remote - Hydraulic remote that mounts on the handlebar.
    RLT = Crown adjust knob - Damper control knob you turn that's mounted on the fork.
    If you want remote, go XX. If you want non-remote, go RLT.
    Irrespective of whatever internet BS you read, the Dual Position is a good system if you want travel adjust. If not, then go Dual Air.
  • 06-27-2012
    KRob
    Thanks for the info. I suspected the main difference was the remote but wasn't sure if anything else was different.
    So is there a relatively simple way to remove the remote from the XX?
    I've located a new 2011 XX for a good price but not sure I want the extra fuss/handlebar clutter of a remote.
  • 06-27-2012
    6thElement
    I think it's a change in damper, so $$.
  • 08-18-2013
    Rey Recinto
    Can the RCT3 damper assembly replace the XX damper with the X-Loc -on my 2011 WC Revelation 150 Fork?
