SRAM X7 Rear Derailleur/shifting issues- Mtbr.com
Results 1 to 2 of 2
    Jul 2015
    So, I took my chain off for a cleaning, put it back on...now runs rough in the smallest rear cog.
    I see that the chain is running inbound (toward the hub) a bit, and cable already slack-ish, so I back out the Hi adjustment screw to move the mech outbound. Nope. Screw is already almost backed all the way out...even all the way out, the rear pulleys are just inbound of the small cog, instead of just outbound per SRAM's manual.
    SRAM's manual says I need 12.7mm of distance between the outer edge of the small cog to the surface where the rear derailleur screws in. Never had a problem before, but I measure it and...I am at 12mm even. WTF ?
    Anyone had this issue before or have advice ? My tire sits as before, and my disc rotor lines up fine, so it doesn't appear that any shift occurred in how the wheel sits in the frame, or is centered. My hanger does not appear bent either...straight as arrow as far as I can tell.
    I am slowly going insane. I've cleaned my chain off the bike like a million times, and adjusted my rear derailleur many many times with no issues at all. I am completely stumped on this one.
    Nov 2015
    This is the best tool I ever got for shifting issues:https://www.amazon.com/Park-Tool-DAG.../dp/B01EONTQMG
    It pretty much fixes every issue anyone who asks me has.
  1. Sram x7 shifting question
    By Wolfe99 in forum Beginner's Corner
    Last Post: 01-26-2017, 10:23 AM
  2. Sram x9 rear derailleur + Sram x7 shifters + shimano cassette (Shifting all messed?!?
    By Angus_fairgrieve in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-04-2015, 05:05 PM
  3. 1x10 sram x7 shifting problems
    By wparrish1986 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 09:01 AM
  4. Replies: 10
    Last Post: 03-17-2007, 02:19 PM
  5. Sram X7 Derailleur = Sram Dual Drive Derailleur $25?
    By mb300 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-22-2007, 03:21 PM
