Sram X1 Cassette, broken splines, can't remove cassette- Mtbr.com
    Reputation: Ducman's Avatar
    My Sram X1 cassette was making a lot of noise and even though it still shifted well, no amount of lube or a new chain would stop it from grinding away. So at about 1000 - 1500 miles, it was time for a new cassette. Which seems like a really short life span, even with chain replacements
    Well, it didn't go to smooth when all the splines snapped at once and now the cassette is permanently attached to the driver. Luckily with the help of Onyx racing, I was able to get the driver off and replace it with a Shimano.
    Nov 2008
    Quote Originally Posted by Ducman View Post
    Sucks, did you use the proper depth splined removal tool? Its very easy to do this with a 10yr old park tool. It sucks, they should have made a different tool/format of spline since the form factor changed.
    Reputation: Bacon Fat's Avatar
    Mar 2016
    I used the park FR-5 since it is what they list on their site as the correct tool. I had the cassette off a few times thinking the noise was coming from the cassette driver interface. It there a different to I should have been using?
    Oops phone had me logged into the wrong account
    Nov 2008
    Yes and no. The fr-5 changed over the years. I just looked at both of mine, the newer one has the depth needed to accommodate the deeper spline depth of the sram. I smoked a cassette this way as well, it royally sucked. Park should NOT have made a new tool with the same model number. Call it "FR-anything but 5" cuz its not the same.
  1. X01 cassette removal, lockring tool won't reach splines??
    By martinizer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-30-2018, 05:04 AM
  2. SRAM 1X cassette vs Shimano XTR M9000 Cassette?
    By Picard in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2016, 08:11 PM
  3. Replies: 6
    Last Post: 02-06-2015, 08:09 AM
  4. Looking for a worn out/broken SRAM XX cassette
    By cwldr20 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-29-2014, 05:04 PM
  5. Can't remove cassette
    By jonathan creason in forum Singlespeed
    Last Post: 09-15-2012, 05:22 AM
