SRAM TwistLoc Lockout Remote Issues- Mtbr.com
Results 1 to 26 of 26
    Reputation: AF2NR's Avatar
    Jan 2018
    Just curious how many people have had issues with this system and on what forks the issues have shown up? I know the Trek TF uses this remote with various forks/shocks, both Fox and RS, and that it also comes on the 2019 Blur TR with Fox fork and shock. The Blur I am picking up had to have the grip replaced while taking it for a ride around the shop, it wouldn't stay open. After it was replaced and on a demo ride it worked fine. I also saw a review of the same bike on YouTube and it had an issue with the stock TwistLoc and had been replaced with a standard remote. Just curious if there have been many issues or just a few from those in the wild?
    Reputation: newking's Avatar
    Nov 2007
    following...in theory this seems like a pretty slick way to lock out a fork or both.
    I'm a dedicated grip shift fan and have the push button thumb actuated lockout on two bikes, it's nice but get's "sticky" when cold and needs a bleed every so often.
    Quote Originally Posted by AF2NR View Post
    Jan 2018
    Quote Originally Posted by newking View Post
    The one that went out on the Blur TR was just the opposite of "sticky". The grip would turn but it would not engage and therefore was locked out. I'm not quite sure if I like or not yet. During the actual demo I unknowingly bumped the thumb button and locked out the fork/shock. Only happened once and it was on relatively tame trails. I honestly think I would prefer not to have the lockout at all but not at the cost involved in reversing the system...
    Nov 2007
    Is the system "twist" to lockout and push button to unlock or can it be set up either way. Seems like twist to lock is the most intuitive IE going uphill your pulling in and locking.
    Jan 2018
    On the Blur it is controlling Fox fork/shock and it is actually push to lock and twist to unlock. Ive heard that you can send them back to Fox to have them reversed but that is costly and if you remove the remote it leaves the system locked as well. It cleans up the bar, but Id rather have the option of using the remote or removing it and be in the open position. It at least cleans up the bars compared to the standard Fox remote.
    The twistloc just pulls cable. The twist pulls cable, the button releases it. So if your fork/shock lock when pulling cable then it is twist to lock. If your fork/shock unlock when pulling cable, then it is twist to unlock.
    Jan 2018
    Well I have now had two of these remotes fail on my Blur TR... RS says there was a period where there were QC/manufacturing issues, they also said this on the first one that was replaced. I would rather have this bike with manual remotes than the system as it is set up. The shop I went to this time said they have had multiple issues with the remote on various bikes.
    Dec 2009
    For those who have the twistloc. Do you have to use the included grip, or can you use a silicone grip that's cut a bit shorted with it?
    Jan 2018
    Quote Originally Posted by jdr120 View Post
    One of the guys with the Blur TR on here actually has done this. He replaced the SRAM grips with ESI Chunky's I believe, and cut the left one to fit with the lockout.
    Jan 2005
    I took my twistlock off to put riser bars on. When I put the twistlock back on it will twist but doesnt "click" for it to stay unlocked. Anyone else have this issue or know what I might have done to cause this?
    Sent from my SM-G935V using Tapatalk
    Jan 2018
    Quote Originally Posted by kbell View Post
    This was the issue I had with my initial TwistLoc that failed in the parking lot before I could even demo it, SRAM said there was a bad batch and sent a replacement. The second one lasted a couple of weeks and SRAM's response was the same as the first time. I'm now awaiting the parts to use the Fox lockout remote and a different dropper/remote. While I'm waiting I'm running my bike in the open position by rigging the suspension with a cable to stay open, and the TwistLoc has been removed for good. Either the new attempt will work or the shop said they will send the shock back in and get a new top cap for the fork so I can run them manual.
    Jan 2005
    How did you rig it. I can only ride mine in locked out mode until I get it fixed
    Jan 2005
    I have ordered a fox lockout from the shop I bought it from
    Jan 2018
    I wish I could tell you but the shop did it actually. I want to say they just used some cable/wire to pull them into the open position. They did this when the first one failed and I saw a little of what they did but didn't pay that much attention, the second time I was changing tires while he did it so I didn't see much.
    I'm sort of stuck now on what I'd really like? While initially I didn't think I'd use the lockout much I did find myself using it. However, now I haven't really found myself missing it so far with having it opened for a couple weeks.
    My shop/SC/Fox got me the remote to try. RS also offered to send another TwistLoc but if they can't replace a bad with a good then I'm not going that route again...
    To rig suspension open
    Normally there is gear cable outer running between the remote and the suspension. Where the OUTER would usually enter the fork/shock insert a gear INNER cable directly. The head of the gear inner that normally sits in the remote, will sit in the stop that the outer usually stops against.
    Run the gear inner through the compression/lockout dial as it normally would.
    Then manually hold the dial so your suspension is open and cinch down the cable anchor bolt on the cable.
    Trim inner cable and crimp a cable end onto it.
    Ride
    Jan 2005
    Quote Originally Posted by aussie_yeti View Post
    Ride
    This was simple and worked perfectly thank you!!!
    Oct 2010
    I cut a pair of ESI grips and it works fine. You need to use the "racers edge" size to match up perfectly with the remote. I assume "chunky" or "extra chunky" will leave an abrupt transition from the grip to the remote.
    Sep 2016
    I'm having the same problem. It takes very little force to the TwistLoc to revert to locked. I'm essentially riding a rigid bike since it won't stay unlocked.
    Jan 2018
    Quote Originally Posted by Alfman View Post
    It seems most people have pretty much removed the TwistLoc to alleviate the issues. I know myself and others are running the Fox remote now, there is more info and pics in the Santa Cruz Blur TR thread in the SC forums.
    Sep 2016
    Ok. I'll check that out. Thanks!
    Sent from my moto x4 using Tapatalk
    Jan 2002
    Does anyone know if these issues have been fixed in current ones? love the idea, its exactly what ive been wanting for a while on my ht with a SC34 120mm.. but not if it works like $h*t...
    Feb 2005
    I also had Twist Loc issues on a Blur TR, I am now using a OneLoc setup which is more durable. The Twist Loc would pop out on random hits, I think it is a flawed product combo with the Fox shock which defaults to locked out. I will not be going back to the Twist Loc, I'm debating have the shock converted to a 3 position, or keeping the OneLoc.
    Jan 2002
    Quote Originally Posted by slipstream View Post
    Yeah sounds like it needs to be redesigned.. fox does make a top cap that springs the other way (push to lock) that I was planning on using.. worldwide has em for $30..
    Sent from my SAMSUNG-SM-G891A using Tapatalk
    Feb 2005
    Good to know, I will definitely be ordering that, it makes more sense to have it default to open IMHO
    Jan 2018
    Quote Originally Posted by hiss2 View Post
    What about the shock? The Trek Top Fuels have also had the same issue so it isn't limited to Fox but seems to be more of a RS problem with the TwistLoc itself. This is my current set-up, which was done free through the dealer and Santa Cruz.
    Attached Thumbnails Attached Thumbnails SRAM TwistLoc Lockout Remote Issues-6f941a31-8b9b-4035-a040-d29b9a17eb42.jpg
    SRAM TwistLoc Lockout Remote Issues-08738232-48fd-4361-ab92-7fe3f70e3fc6.jpg
    Jan 2005
    I went this route too
  1. Possible to use Rockshox Twistloc on Fox suspension?
    By GoranH in forum Shocks and Suspension
    Last Post: 11-12-2019, 03:28 AM
  2. Fox F32 remote lockout & RP2 "lockout"
    By SoftballGuy in forum Shocks and Suspension
    Last Post: 01-06-2014, 05:06 PM
  3. Replies: 3
    Last Post: 01-04-2013, 09:34 AM
  4. Replies: 32
    Last Post: 12-18-2012, 09:51 AM
  5. DT M210 remote lockout, lockout doesn't work
    By Danne in forum Shocks and Suspension
    Last Post: 10-03-2011, 12:43 AM
Members who have read this thread: 53
