SRAM/TruVativ XX compatible Q-Rings- Mtbr.com
Results 1 to 18 of 18
    Reputation: nofish's Avatar
    Just a couple questions,
    When switching over to the 40/27 do I need to change anything?
    Will my Factory chain still fit?
    Reputation: madskatingcow's Avatar
    Yup! No need to change anything.
    I've swapped my 42/26T Specialized rings with 40/27T, working great.
    At the highest point, the 40T Q-Ring corresponds to a 42T 'round' ring, at the lowest point with a 38T.
    I am going from a 39-26 Stock >>>> 40-27 Q-Rings.
    Apr 2005
    Do you by any chance want to sell the 39t chainring...
    Dec 2008
    Quote Originally Posted by madskatingcow
    Hi MSC-
    Did you have to change the chainring bolts or are the rotor XX rings threaded like the original ones?
    Cheers
    B.
    Reputation: oldassracer's Avatar
    tagged - interested
    It is possible for rice to absorb other odors in storage. Or could be the quality of water in it was prepared. Mahatma Rice
    Quote Originally Posted by bobsouth
    Well, I've swapped my the original 42/26T rings of my Specialized S-Works cranks with Rotor Q-Rings 40/27T. The original bolts fit perfect, I assume the same for the SRAM XX crank.
    I have ordered Rotor Q-Rings 40/27T for my Cannondale Flash, to replace the stock XX 42/28T rings. They should be in early next week.
    Weight difference?
    Greater chance of dropping the chain?
    My SRAM XX compatible Q-Rings arrived today
    Apparently, smaller bolts are needed (and were included).
    Never had any issues with the Q-Rings on my Specialized S-Works cranks, chain never dropped off once.
    Weight differences?
    Don't know and doesn't interest me. These weigh 96g according to the Rotor website, perhaps via Google you can find the weight of the XX Q-Rings.
    gone for a bike ride
    Reputation: culturesponge's Avatar
    rings looks better in black
    please post installed pic + first impressions
    Mine did not come with the Extra Bolts needed, I had to purchase some chainring bolts.
    For almost $300.00 I would think the Rotor bolts would look nicer.
    Maybe I need to call Rotor.
    Feb 2005
    Chain Suck?
    Running 2x10 Rotors on my Epic with KMC chain, anyone having chain suck problems?
    Nope, none at all - running the SRAM PC1090 chain
    Reputation: Jasontech's Avatar
    I have Truvativ Noir Redwin Carbon, 44/32/22 and I was wondering if I could replace the rings and get the XX 26-39? Also if this does work can I keep the same chain or do I have to go to something else? and will my XT Front Derailleur still work or will I have to get the XX Front Derailleur?
    Thanks,
    Jason.
    Team Captain
    BCD is different between Noir and XX cranks. No go.
    benefits and differences?
    ok - those of you running these -
    What benefits have you noticed?
    Are you running any comparisons with power meters or standardized time trial?
    Please share your Subjective differences in before and after conversion to the Rotor Q Rings
    thanks
