SRAM Level T Brakes - Loose Pivot Pin for Lever- Mtbr.com
    eastman
    Reputation: eastman's Avatar
    I'm about a year into these brakes and while riding today, noticed the Pivot Pin was coming out during a ride. Every few minutes, I had to push the Pin back in to keep the Lever attached. Looks like a pressed pin and not sure if you can replace/fix this problem with another pin.
    Anyone else run into this problem?
    The SRAM parts catalog does have what looks like a replacement for the TL (see below), but nothing for the Level T. Thanks for any help.
    Name:  2018-04-15 21_00_25-sram_spc_revc.pdf.png
    Aug 2017
    Dec 2017
    I believe it's pressed in. It also renders the lever blade permanently attached and therefore it can't be replaced. I intend to replace mine with Guides at some point--on that has a replacement lever blade in case I crash again (one of mine is bent).
    eastman
    FYI, called SRAM customer service and they do not sell small parts for Level T series. Luckily, the brakes are under a year old and qualify for warranty replacement. Not sure if they will replace one or both yet, as I am now concerned this may happen to the other brake lever as well.
  1. TB3 Sram level TLM brake lever not rebounding
    By MilRob in forum Santa Cruz
    Last Post: 07-28-2018, 03:40 AM
  2. Removing brake lever pin on Shimano M396?
    By phile in forum Brake Time
    Last Post: 01-26-2018, 08:43 PM
  3. Replies: 11
    Last Post: 03-06-2013, 07:38 PM
  4. Brake lever pin keeps falling out
    By CyclesnIPAs in forum Brake Time
    Last Post: 01-20-2013, 08:06 PM
  5. Avid Lever Blade Pivot Pin, Where to Buy?
    By Thatshowiroll in forum Brake Time
    Last Post: 10-14-2012, 06:59 PM
