Sram GX 11 speed shifter - lever reach adjustment?- Mtbr.com
Results 1 to 2 of 2
    Nov 2008
    Gang,
    Does anyone know if on a Sram GX 11speed shifter the down shift lever can be adjusted in terms of lever reach? I find it to be angled a bit too far out towards the rider and I would like to move it to be more in parallel with the bar. The lever I speak of is the one that pulls the cable and makes the rear mech. move the chain into into a larger gear.
    Ive looked at the unit and there is a few screws on it, but none of them look like adjustment style screws.
    Sram has a document about the unit, but there is very little wording on it and my unit does not appear to have the screw they speak of. This is the document I was looking at:
    https://sram-cdn-pull-zone-gsdesign....b_shifters.pdf
    I just don't see that T25 screw they depict in the drawing (lower center-right)
    RAKC
    Reputation: tigris99's Avatar
    Its a trigger shifter, someone speak up if there is any that exist that have adjustments, cause afaik no such adjustment has ever existed on a basic trigger shift
    No the GX shifters dont have reach adjustment, rotate the shifter on the bars to get comfortable position.
  1. Question about XT M785 lever reach adjustment
    By kapusta in forum Brake Time
    Last Post: 04-27-2016, 01:32 PM
  2. SRAM lever reach adjust broken
    By mack_turtle in forum Cyclocross
    Last Post: 09-09-2015, 02:47 PM
  3. Reach adjustment for Sram DB5 brakes?
    By NWS in forum Brake Time
    Last Post: 07-18-2015, 08:01 PM
  4. Brake Lever Reach Adjustment
    By dharel1705 in forum Brake Time
    Last Post: 05-30-2012, 10:56 AM
  5. Reach Adjustment on Speed Dial 7 levers?
    By fueledbymetal in forum Brake Time
    Last Post: 02-24-2012, 07:22 PM
Members who have read this thread: 4
