Is the SRAM Eagle NX cassette compatible with Shimano HG50, 11-42, 10 speed cassette- Mtbr.com
Results 1 to 7 of 7
    Reputation: EisGary22's Avatar
    Apr 2019
    Is the SRAM Eagle NX drivetrain a compatible replacement of the Shimano HG50, 11-42, 10 speed drivetrain.
    The current Shimano HG50 system is stock on my 2019 Trek Stache 5. As far as what hub the bike is using, it's a Bontrager alloy, Boost 148.
    Jul 2017
    In short, yes. Because the NX Eagle uses the shimano freehub (aka HG) standard as well, hence the 11t smallest cog.
    But you’ll have to upgrade the rest of your drivetrain to 12spd if you choose to replace the cassette.
    Apr 2019
    Thank you for your reply.
    FYI, I do have the Eagle NX group set. And I just wanted to confirm that it was compatible with the current Shimano HG50 10 speed group set.
    Reputation: LyNx's Avatar
    It is NOT compatible with the Shimano 10spd groupset, it is compatible with a hub that uses an HG driver, BIG difference.
    Quote Originally Posted by EisGary22 View Post
    Quote Originally Posted by Harold
    You're doing mtbr wrong, you're supposed to get increasingly offended by the implications that you're doing ANYTHING wrong.
    Jul 2017
    My bad, OP actually worded his question differently in the title and in the post..
    Apr 2019
    Isn't the Shimano HG50 cassette using a HG driver? If so, won't the Eagle NX use the same driver.
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    As others have said the NX cassette does fit an HG freehub.
    I ran one on my trainer through the winter months. I did find that shifting on it wasn't the smoothest, it very much clunked between gears.
  1. SHIMANO 10 SPEED 11-42 vs SUNRACE 11-42
    By hamsterboy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2019, 07:10 AM
  2. Sram NX 1x11 vs NX Eagle 1x12
    By MattBMS150 in forum 27.5
    Last Post: 03-12-2019, 05:00 PM
  3. 11-42 10 speed to 11-46 11 speed.
    By richwolf in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-14-2017, 03:53 PM
  4. 11-42 xt 11 speed cassette with old 10 speed shadow plus derailleur
    By 305coco in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-29-2016, 02:11 PM
  5. sunrace 11-42 10 speed vs shimano/sram 11 speed
    By goodmojo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-30-2016, 05:59 PM
Members who have read this thread: 9
