SRAM 1x compatibility question (cx content)- Mtbr.com
    May 2012
    i want to convert my 2x11 system to 1x11. i know i'll need a new crank, cassette & derailleur (to get the size/range i require) but will i need a new shifter?
    I've got a rival 22 shifter, and i plan on using a rival 1x derailleur, so are the 2 compatible? or will i need a new shifter too? both are 11 speed, so they should be ok, shouldn't they?
    also, is there anyway to remove the shifter part of the right hand shifter/brake lever? given that the shifter part will be redundant....
    Apr 2005
    Why wouldn't they work? You can remove the guts of the shifter but it's the left one you want to do it too....not the right. Also why do you need a crank? Just buy the chain ring...assuming your crank is 110BCD.
    Yes, Rival1 rear derailleur will work with your Rival22 shifters.
    It's a bit tricky to get to the shift mechanism in the left lever but it can be done. A much easier solution is to just remove one circlip and drop the lever out. Then you get the clean look of 1x. The shifter guts will still be in there but it'll save you a heap of time (at the expense of about 40 grams.
    May 2012
    oops... yeah i meant the left one!
    and good call ref just removing the lever
  1. SRAM v XT compatibility
    By miggy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2016, 11:54 AM
  2. Compatibility question SRAM/Shimano
    By asuprice in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-17-2015, 08:27 PM
  3. Rear Sram XX compatibility question
    By 0000 in forum Beginner's Corner
    Last Post: 12-19-2014, 06:36 PM
  4. Sram XX with 9 spd compatibility
    By nrsnow in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-27-2011, 05:53 PM
  5. Sram and Shimano Compatibility question
    By emiliobuckmaster in forum General Discussion
    Last Post: 03-01-2011, 08:15 PM
