Spider bolts- Mtbr.com
Results 1 to 2 of 2
Thread: Spider bolts
    Reputation: sml-2727's Avatar
    Nov 2013
    Spider bolts
    After I took my spider off my crank and went to the direct mount,there are three bolts/screws that hold on the chainring that have a star pattern on them,I stripped one of them out and need to replace it, problem is I can't find them anywhere. Any leads to where I can buy them? When you search for chainring bolts something else comes up.
    thanks
    2017 Surly Ogre
    most disc brake rotor bolts work. they use the same thread diameter and pitch. just get one with a similar head size. they're a little bit longer but don't bottom out inside the crank arm.
  1. Spider 29c pivot bolts loosening
    By biketavioumaximus in forum Intense
    Last Post: 06-09-2016, 04:40 PM
  2. Using disk rotor bolts instead of SRAM direct mount chainring bolts
    By agu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-08-2016, 07:13 AM
  3. Replies: 9
    Last Post: 07-16-2012, 01:52 PM
  4. Replies: 1
    Last Post: 02-28-2012, 08:14 PM
  5. Syncros Revolution spider/inner ring bolts & spacers?
    By RockiMtn in forum Vintage, Retro, Classic
    Last Post: 05-18-2011, 08:46 PM
