SID Charger vs Charger 2?- Mtbr.com
Results 1 to 5 of 5
    I can't find the answer to this question anywhere. Was the SID offered with the Charger, Charger 2, or both? Some stuff I've read leads me to believe that it first had Charger in 2017 then Charger 2 in 2018. Other stuff seems to indicate it has had only Charger 2, never Charger. Which model year has Charger 2 and how can I be absolutely sure when buying used?
    Quote Originally Posted by B R H View Post
    Did you ever find an answer to this? I am wondering as well
    The info in my post is correct. The only way to properly ID model year is by the manufacturer part number that seems to only be on a sticker on the original box. I'm not sure why this information is so hard to get or verify. I'm still not convinced the forks don't have useful information on the fork itself but probably won't know for sure without actually seeing one in real life (and they're hard to find).
    Reputation: Aresab's Avatar
    I took a look at the spare parts catalog on SRAM.com, from what I can tell there is only a Charger 2 in 32MM which came out in 2017. There appears to be a XX and and RL version of the SID as well in 17í. Iím fairly sure the Charger (1) was only offered in 35mm, Pike, Lyrik, Boxxer.
    all SID's w/ Charger are Charger 2
  1. Replies: 6
    Last Post: 05-01-2017, 09:04 AM
  2. Lost my Lupine Charger One charger
    By Flyer in forum Lights and Night Riding
    Last Post: 09-18-2016, 09:50 AM
  3. New Sid charger damper in old Sid chassis.
    By Floor Tom in forum Shocks and Suspension
    Last Post: 07-09-2016, 09:28 PM
  4. Sid Charger Damper.....
    By durkind in forum Shocks and Suspension
    Last Post: 05-07-2016, 01:14 PM
  5. Sun Ringle - Charger Comp vs Charger Expert Wheelset
    By HenryK in forum 29er Components
    Last Post: 11-20-2014, 01:35 AM
