• 11-16-2016
    jeffscott
    Settting Up an Eagle xx1 RD
    So everything ended up fine...
    But the SAM online instructions appear to be wrong
    When you set the B Screw with red guage you have to have the chain installed, and the bike at full sag...
    The pictures omit the chain...so basically I had to do it twice...
    Followed a youtube video the second time around
  • 11-17-2016
    mtnbikej
    You mean these ones:
    Attachment 1105909
    Attachment 1105910
    Looks like the indicator of a chain is there. :thumbsup: :madman: :eekster:
  • 11-18-2016
    jeffscott
    I seen the greyed in incomplete chain....(Used the coloured pictures from the SRAM site)
    They never say or show or indicate a real chain is required to be installed prior to this step.
  • 11-18-2016
    mtnbikej
    If you followed the directions...
    https://sram-cdn-pull-zone-gsdesign....ser_manual.pdf
    Page 8 -13 tells you how to size the chain for FS rigs
    Page 14 tells you shift the chain into the largest cog with the bike sagged into it's travel, before setting the chain gap.
    Seems pretty clear.
  • 11-18-2016
    jeffscott
    Seems pretty clear.
    You make my point???
    The directions are not clear and specific...
    That iOS why the youtube worked....I just followed the mechanics steps.
  • 11-18-2016
    mtnbikej
    Why would you follow steps 8-13 only to remove the chain for step 14. Step 14 tells you to shift the chain into the largest cog with the bike sagged "before setting chain gap".
    Again, I'm not sure where you got lost. The directions are pretty clear.
  • 12-18-2016
    useport80
    Attachment 1105909
    Attachment 1105910
    Looks like the indicator of a chain is there. [emoji106] :madman: :eekster:
    where can I get one of these red tools? I can't seem to find the b tension gap tool anywhere
    Sent from my SM-N910V using Tapatalk
