setting up rs revelation 140mm- Mtbr.com
Results 1 to 3 of 3
    yorkshire mud monkey
    Reputation: sausagedog's Avatar
    i have a revelation 140mm think its 08 what is the best way to set it up right
    eg poss or neg 1st,as ive seen people with issues after doing it the wrong way round.
    as steve said "As long as the rotor/rivets clears the fork, a miss is as good as a mile"
    Doesnt ride Banshees
    Reputation: Banshee Rider's Avatar
    Always fill the positive first. Always drain the negative first.
    Start with your +/- equal, and make pressure adjustments as you see fit after riding it.
    Don't exceed >5psi in the negative chamber, or the fork will "shrink" or "lose travel."
    More + air = less bob, better pedaling performance. More - air = better small bump compliance, more bob.
    i have them both set at about 160, ive never had any of this + and - air before so its all new and with all the issues that people say they have with them just wanted to make sure they were set right
