RShox All travel kit is 10mm increments?- Mtbr.com
Results 1 to 3 of 3
    Reputation: Jingleman's Avatar
    Sep 2004
    hello
    I would like to increase the travel on my Recon 327 Solo air from 100 to 120mm (2007 OEM model on Giant Trance 2007).
    On the service manual the drawings show 3 possible configuration: 80-100-130 mm ( 3 different spacers of 50-30 and 20 mm)
    but I see that there is an all travel kit which is 5 plastic spacers molded together to be cut to desired leght..is it right?
    If so I could get any travel I want from in 10mm increments? (80-90-100-110-120-130).
    Or If Im totally wrong ..do you know if I can get 120 mm from a 2007 solo air recon fork?
    Thanks a lot
    p,s, the all travel kit Im talking about is the black one on the top ,and on the exploded drawing it is part n.15-16
    Attached Thumbnails Attached Thumbnails RShox All travel kit is 10mm increments?-rockshox_all_travel_spacer_kit.jpg
    err, 27.5+
    Reputation: AL29er's Avatar
    The AT kit comes with three lengths of solo air spacers. Of course you could custom cut the longer ones to whatever length you want. Here are the details of the kit
    Quote Originally Posted by saturnine
    that's the stupidest idea this side of pinkbike.
    Sep 2004
    ohhhhhhh thanks so much !!!! that's great
    given that I have a recon 327 with 100mm travel..it should have the 30mm spacer inside it, right?..So if I can manage to divide it in two pieces of 10mm and 20mm, with some accurate cutting..I could use the 10mm spacer and get 120 mm travel..right?
    thanks again
