Rockshox Lyrik Solo Air 08 All Travel Spacer Kit- Mtbr.com
Results 1 to 6 of 6
    can the Rockshox - All-Travel Spacer Kit be used for the lyrik 08 solo air?
    i havnt found anything about it, or any othe way to reduce to 130 - 140mm?
    Reputation: G-AIR's Avatar
    Quote Originally Posted by hemn
    I believe it can. It is hard to find any info, but I have been researching lately and it sounds like a go. There is a little bit of info in the SRAM tech. manuals online. It shows where the spacers go. I also emailed a SRAM employee and he said it was good to go. He did recommend a licensed shop do the work.
    I will be lowering a 2010 Lyric to 150 mm in the near future.
    TG
    please post it when you did it
    pics would be great
    I'm sure they use the same spacers on their other internally adjustable air forks. It should be really easy to do. So, pull the trigger!
    I don't wear a helmet, I wear a turban protector!
    Mar 2006
    Quote Originally Posted by G-AIR
    TG
    Any joy?
    Mar 2006
    Any joy with the travel adjust on the solo air lyrik?
