• 12-20-2009
    hemn
    Rockshox Lyrik Solo Air 08 All Travel Spacer Kit
    can the Rockshox - All-Travel Spacer Kit be used for the lyrik 08 solo air?
    i havnt found anything about it, or any othe way to reduce to 130 - 140mm?
  • 12-20-2009
    G-AIR
    I believe it can. It is hard to find any info, but I have been researching lately and it sounds like a go. There is a little bit of info in the SRAM tech. manuals online. It shows where the spacers go. I also emailed a SRAM employee and he said it was good to go. He did recommend a licensed shop do the work.
    I will be lowering a 2010 Lyric to 150 mm in the near future.
    TG
  • 12-21-2009
    hemn
    please post it when you did it:)
    pics would be great:thumbsup:
  • 01-06-2010
    peedrama
    I'm sure they use the same spacers on their other internally adjustable air forks. It should be really easy to do. So, pull the trigger!
  • 03-03-2010
    hora
    TG
    Any joy?
  • 03-03-2010
    hora
    Any joy with the travel adjust on the solo air lyrik?
