Road Bar SRAM Shifters- Mtbr.com
Results 1 to 3 of 3
    I need a SRAM shifter that is compatible with a MTB rear derailler and a road drop bar. What options do I have? It is for a commuter and does not have to look pretty. I would prefer something that is relatively inexpensive. I thought the grip shifters would work before remembering that the bars were different diameters. I do not really want the double tap shifters.
    Tribe Member
    Reputation: yetirich's Avatar
    Sram does make bar end shifters.
    Since you dont want the double tap road shifters, you could try to mount any of the trigger shifters to a road bar and "massage" it around until it gets in the right position for you.
    You could use a grip shifter and just keep it at the bottom of the bar like a bar end shifter and that would work also.
    Good luck
    Proud Tribe member since 1992 - looking for better singletrack to be ridden year round
    The grip shifter was my first choice, but road bars are a different diameter, or at least the ones that I have are. I'm aware of the bar end, I was just looking for other options out there.
    Has anyone used a grip shifter on a road bar?
