The right way to install Pike lowers. Extend or compress?- Mtbr.com
    Is there are recommended way to install the lowers on the Pike?
    One one hand you can extend the damper and and air shafts fully and install the lowers at full extension.
    On the other hand you can compress the lowers as far as you would like before engaging the damper and air shafts.
    One way will leave the pressure in the lowers equal to the outside but should also assist the solo air spring in support of the fork under compression. The other way will create a vacuum in the lowers once the solo air spring is pumped up and the lowers are extended, and I assume assist the negative air spring making the fork more supple as well as making it more linear in it's travel.
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    I always install with them about half.
    Theres so much elevation change that air pressures in the lowers fluctuate and sometimes need a burp anyways. The end of a zip tie between the stanchions and seals work great.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    I do them with the air spring rod fully extended. Done it half way before and this gives you a neg spring off the top. Though it may equalize with time.
    Pretty sure the SRAM way is with the rods extended.
    I <3 dirt
    Oct 2010
    Not only will it equalize but it'll build pressure over time, hence the burping.
  1. Pike won't fully extend after travel change
    By fdes in forum All Mountain
    Last Post: 11-02-2018, 12:30 PM
  2. Pike....can I change my 26'' lowers to a 29" lowers for new bike?
    By exploder in forum Shocks and Suspension
    Last Post: 09-02-2015, 01:52 PM
  3. Can RS pike 27.5 lowers fit on a 26" pike Stanchon tubes?
    By ToneLOcust in forum All Mountain
    Last Post: 02-20-2015, 03:41 PM
  4. Pike 327 stored 3 months... won't compress.
    By Desert Rider in forum Shocks and Suspension
    Last Post: 09-27-2011, 05:21 AM
  5. Reba won't compress/ lowers stuck
    By M_S in forum Shocks and Suspension
    Last Post: 08-07-2011, 10:00 PM
