Repairing Eagle chain- Mtbr.com
Results 1 to 6 of 6
    May 2016
    The missus somehow damaged a link on her hollow pin X1 Eagle chain -- probably hit a rock -- and now it's very much frozen. The chain only has a few hundred miles on it.
    Options:
    1. Toss it
    2. Take out the damaged section and run three lovely powerlinks: the one that's already there, plus two more surrounding the replaced section.
    3. Take out the damaged section and replace via pressing pins in with chain tool.
    Given the cost of these chain I don't want to do #1. Given the cost of powerlinks I don't really want to do #2 either. Also, I live in Zambia most of the year so they are a bit hard to come by.
    Opinions?
    Thanks,
    Kevin
    First, in your case, do #3 if you can find them. If that doesn't work the cheapest long-term solution is to buy a new chain. You always shorten a new chain and end up with extra links. Use some to repair your current chain. When it wears out replace it with the spare you bought. No loss.
    Ride Fast Take Chances :)
    Reputation: alexbn921's Avatar
    You can't use press pins with an eagle chain. The factory pins are molded flush with the links.
    Quick links would work and I don't see much downside to that option.
    Me personally I would replace the chain. If one link is bad a couple others are probably bad too.
    West Chester, PA
    Quote Originally Posted by eb1888 View Post
    No. You can not replace pins on a sram or kmc chain. The pins are flared during manufacturing and the flare on one end gets torn off when it is pressed out. If you re-install it, the chain will break. This applies to 9, 10, 11 and 12 speed chains.
    Reputation: mfa81's Avatar
    you fix a chain to get home then you replace... I donít see much benefit in trying to save some money... get a gx chain which isnít that expensive and donít risk a broken chain while out riding!
    Magically Delicious
    Reputation: Cleared2land's Avatar
    Best option and my advice too.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. best Drivetrain-- eagle or hybrid eagle?
    By SB Trails in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2017, 05:11 PM
  2. xo1 eagle cranks stronger then xx1 eagle cranks?
    Last Post: 06-30-2017, 10:07 PM
  3. SRAM Eagle chain with xx1 (non-eagle) chainring.
    By LyncStar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2017, 05:19 AM
  4. Federal Government / Bald Eagle and Golden Eagle death proposal.
    By DIRTJUNKIE in forum Off Camber (off topic)
    Last Post: 07-05-2016, 08:14 AM
  5. RockShox Ride Experience at Eagle Bike Park in Eagle, Idaho
    By lil29er in forum Idaho, Montana, Wyoming
    Last Post: 06-28-2012, 04:56 AM
