Predictive steering hub dimensions?- Mtbr.com
    Hello, I'm planning to make an adapter for a Hope hub to fit a RS1. I'm looking for the predictive steering hub end cap diameter and the distance from the end of the axle to the brake rotor mounting flange. Any help would be great! Thanks
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Did you ever do this? If so, how did it work out?
    Death from Below.
    The standard ditsance are 10.5mm in RS1 hub are 12.5 or 13mm I'm not 100% sure, its dificult messure, but the caliper adjust can solve this error.
    I'ts important that this are very solid, because RS1 rigidity it's cause from hub rigidity. Can make a solid axle of 20mm diameter and use a internal stock spacer. The caps can be thread to axle or to pressure with o-rings.
    After, need a realigment the wheel,but this works fine for equal spoke tensions in both sides.
    Sorry for my basic english, hope you undestand something.
    Regards.
    It's the axle
    Reputation: Gregg K's Avatar
    Ha! I'm just getting ready to do this with an Industry Nine wheel. Extensive searching brought me to this post. Couldn't help but replying even if it's a dead thread.
    Note to self: 85% of FTP for 20 min.
  1. Predictive Steering Hub and the SR-1
    By SSportakus in forum 29er Components
    Last Post: 10-01-2015, 07:14 PM
  2. Self-steering tires
    By efuss in forum Fat bikes
    Last Post: 09-25-2014, 07:57 AM
  3. Replies: 3
    Last Post: 08-04-2014, 02:58 PM
  4. Why no steering dampers?
    By Curler in forum Downhill - Freeride
    Last Post: 02-01-2012, 06:08 PM
  5. Steering vs Leaning
    By AZBob in forum Arizona
    Last Post: 07-18-2011, 12:21 PM
