Pike lower service. Air in negative chamber?- Mtbr.com
Results 1 to 2 of 2
    I have the lowers off, I let all the air out and even removed the valve core.
    There is still some pressure pushing the air-side piston rod to full extension. It's not exactly a firm pressure, I mean I can push it all the way with hand force, but should it be there? I assume there is pressure in the negative spring, but shouldn't it suck up the rod, not push it down.
    Is this something that may be reducing my small bump compliance?
    Sorry if this is a dumb question.
    Nov 2008
    Quote Originally Posted by coolatt View Post
    It might be the negative air chamber, a vacuum was likely created after you evacuated the positive chamber and cycled the piston rod.
  1. Can't remove bolt on pike drive side for lower leg service
    By fdes in forum Shocks and Suspension
    Last Post: 01-22-2018, 09:05 PM
  2. Pike 160 RC 2016 27.5 lower leg Service
    By PornMunky2k5 in forum Shocks and Suspension
    Last Post: 08-31-2016, 09:37 PM
  3. Replies: 5
    Last Post: 04-18-2016, 02:50 PM
  4. RS SID negative chamber oil leak (?)
    By Devastazione in forum Shocks and Suspension
    Last Post: 08-28-2012, 09:05 AM
  5. oil leaking from negative air chamber - big deal or not???
    By surftime in forum Shocks and Suspension
    Last Post: 09-27-2011, 07:57 PM
