Pike Boost and Non-Boost damper swap. Anyone done it- Mtbr.com
Results 1 to 2 of 2
    I am getting a new bike with a 27.5 160mm Pike RC, boost. My current fork is a 27.5 160mm Pike RCT3, non-boost.
    I thought I would swap the dampers to put the RCT3 damper on the new fork. Doing some research I see that RCT3 damper, boost and non boost have different part numbers. Is there actually a difference? What would it be? For example the air shaft part numbers are the same. My assumption was that boost and non boost pikes would be the same internally just different in the upper and lower castings.
    11.4018.009.030 Damper Internals Right Charger PIKE RCT3 27.5 Crown Adjust
    11.4018.009.076 Damper Internals Right Charger PIKE RCT3 27.5 Boost Compatible 15X110 Crown Adjust
    Jan 2014
    If you're technical, swap can be done. It will require a full bleed of damper.
    Main difference is in the thread-pitch of the top cap. Besides swapping the damper, you would also have to swap the cap to ensure your new damper will fit.
  1. Non Boost cranks on Ripley LS with boost
    By marcus_dukakis in forum Ibis
    Last Post: 09-27-2017, 10:56 AM
  2. Replies: 6
    Last Post: 05-01-2017, 09:04 AM
  3. Niner RKT 9 with boost conversion and non-boost crank ?
    By philreske8614 in forum 29er Bikes
    Last Post: 08-30-2016, 10:57 PM
  4. Replies: 0
    Last Post: 04-26-2016, 04:03 AM
  5. Boost or non-boost fork for 5010v2?
    By furball in forum Santa Cruz
    Last Post: 02-03-2016, 09:10 PM
