Nx 12s cassette install- Mtbr.com
    Anybody have issues installing a nx 12s cassette on to hope pro4 hub? The big ring carrier is loose? The same cassette was installed on the stock wheelset with out issue and now using the same setup it wobbles. Is there a need for an additional spacer? Any insights or suggestions are appreciated.
    Reputation: solarplex's Avatar
    Apr 2014
    Quote Originally Posted by Olie12 View Post
    If its a 11 speed road free hub you need a spacer. I have one on my dt swiss hub because of this.
    Fatbike, XC bike, Gravel Bike....
    Thanks ill give it a try. Its the standard shimano freehub that comes on hope pro4 hubs.
    Trust your turbo lust
    I just installed the nx 12spd cassette on my bike, the first time, the big rings were a bit loose and the higher gears, 6+ were not straight. I kept thinking that I might have got a defective cassette. I took it off and checked each gear as I went, making sure to line it up correctly. when I got to the last gear, it looked like it went on straight, but it was actually about a 1/4 turn from where it should have been. there is so little left of the freehub at that point that you can easily misalign the last gear and have it look straight, until you tighten down the lock ring. it will get tight, but the cassette will have a lot of play. I made sure to get the last gear lined up properly and everything went together and tightened down as it was supposed to.
    an easy way to tell if it is close, look at the face of the gears and line up the part where is has the tooth count stamped into it.
  1. 11s vs. 12s chain width, compatibility
    By djbahool in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 1 Week Ago, 05:50 PM
  2. SRAM 12s Chainline Tolerance vs L/R Varience Possibilities
    By deVries in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-21-2018, 08:48 AM
  3. Cassette install question on new wheels
    By Gokart2 in forum Wheels and Tires
    Last Post: 03-15-2011, 12:51 AM
  4. Building up to 12s, 24s
    By normZurawski in forum Endurance XC Racing
    Last Post: 09-21-2006, 02:15 PM
  5. 04 XT crankset install on NRS install question
    By dirt diggler in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-13-2004, 08:04 AM
