nx 11-speed x-actuation trigger shifter rebuild- Mtbr.com
Results 1 to 1 of 1
    Reputation: Nandus's Avatar
    Dec 2011
    While trying to replace the cable my NX 11 Trigger Shifter, I accidentally dislodged the small wire like spring sitting above the coil like spring.
    Unfortunately, Sram doesn't have a decent rebuild guide specific to this shifter on their website.
    I went to my local "Authorized Sram dealer" and the mechanic was able to get the shifter partially working, but the lever it gets stuck while shifting to a higher gear and does not return to it's normal position after shifting.
    I'm really trying to avoid having to buy a completely new shifter.
    Any guidance would be greatly appreciated.
  1. SRAM NX 11-speed shifts like s$$t after installing 11-46 cassette
    By HerrKaLeu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 3 Weeks Ago, 06:25 AM
  2. X-Actuation and Exact Actuation
    By eliflap in forum SRAM
    Last Post: 02-25-2020, 04:35 AM
  3. sram x0 9 speed derailleur exact actuation 1:1 with a 10 speed or 11 speed shifter
    By ReturnOfTheMTB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-22-2017, 03:06 PM
  4. Can I run an SRAM "exact actuation" front derailleur with a Shimano shifter?
    By ljsmith in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2012, 08:49 AM
  5. 11:11:11 on 11/11/11 and you were where?
    By giantbikeboy in forum Riding Passion
    Last Post: 11-17-2011, 05:41 PM
