New Reverb 1X remote lever- Mtbr.com
Results 1 to 26 of 26
    Anybody have the new Rockshox Reverb 1X lever yet?
    Oct 2016
    Don't think it is for sale yet. At least not at my LBS or anywhere online that I have seen. I was told local supply delayed until June or July.
    Mar 2014
    I heard mid May but I'm not holding my breath.
    Reputation: Just J's Avatar
    Feb 2005
    Picked mine up today. Just posted this to my Waltworks Ultimate Warrior thread:
    Probably the best invention since the... Dropper post!
    Had a quick spin and I really like the position and lever feel, Rockshox really have knocked it out the park with this one in my opinion!
    Any questions, just ask...
    Sent from my iPhone using Tapatalk Pro
    Reputation: RS VR6's Avatar
    Does it come with the Discrete clamp?
    I went to a couple local shops and when I asked for the lever...they had this puzzled look. Then they are like ohhhh after looking it up.
    Feb 2005
    Quote Originally Posted by RS VR6 View Post
    Yes it comes with a clamp and the new bleed kit, I chose to run a Hope Matchmaker to keep things clean on the bars. I had my LBS order this kit the day it was announced. They arrived in stock on Thursday last week.
    Sweet, I'll order one in the next couple weeks. GF's birthday and Vegas left me pretty spent last week.
    Reputation: DeeZee's Avatar
    Jan 2005
    Got the last one from my LBS and all I can say is wow.....great upgrade.
    How did you fit the lever to your Hope brakes I'm getting the lever from CRC in the next day or so and want to do the same as yours on my V4's
    Feb 2005
    Quote Originally Posted by PornMunky2k5 View Post
    You'll need the Hope SRAM Matchmaker adapters, it screws into the bottom of the brake and onto the top of the Reverb remote.
    Cheers mate part ordered
    Feb 2005
    Good stuff and no problem!
    Cheers for the extra picture that makes much more sense now as to how it fits
    Thank you
    Feb 2005
    Thank you
    No problem, I thought it might help.
    Finally got my new lever installed, had a few issues bleeding it but got there in the end.
    Feb 2005
    Looks good!
    Feels good too lol
    How did you find the bleed process, I seemed to be dragging air out for ages before I thought that it would do
    Feb 2005
    Feels good too lol
    Yup same here, mine had some play in before the bleed though and now it is as good as new.
    I'd get to a point where only tiny bubbles were coming out then huge bubbles would appear I'm wondering if it was the connection between the bleed port and the connector
    Reputation: spyghost's Avatar
    Oct 2012
    - Where did you guys get your kit from?
    - Did yours come with a new barb AND a new hose - mine didn't?
    - Did you remove the compression nut and re-install new barb?
    i posted this on the reverb thread: RockShox Reverb Thread - Page 29- Mtbr.com as mine was bubbling after a seemingly successful bleed
    TBH, I was so happy with the ergonomics of this lever until i experienced the post becoming hard to push down and slower to get back up. when i checked it was leaking at the connection. Hopefully this is just an isolated incident and not RS screwing things.
    It would have been totally awesome except for the glitch I experienced and possibly missing part(s) from the kit. It's under warranty, but then it's a bummer.
    Mounted with an m8000 lever and problem solvers mismatch adapter lh 1.2
    Canfield Yelli Screamy
    Oct 2012
    check my post above - that was the exact same scenario i had. it felt as if bleeding the remote was impossible and that the bubbles never disappear. If they do disappear (giving the impression of a good bleed), a press of the lever will leak at the hose connection.
    Oct 2012
    I think I've fixed my issue: RockShox Reverb Thread
    https://r.tapatalk.com/shareLink?sha...1&share_type=t
    My reverb 1x remote is unacceptably slow in temps below 70 F. Works great at 90 F. I've bled it, re-mounted it, and it seems fine until it gets in upper 60s. Then 2 seconds to rise. Anyone else? My riding buddy has exactly the same symptoms.
    Reputation: DucatiRider's Avatar
    Oct 2014
    Reviving an old thread: I have two bikes each has an aftermarket 1X remote installed. Both installed the same way, bled the same way and ridden the same way. One bike has worked perfectly since install. The Reverb never loses speed, leaks, etc. The other does not leak fluid at the post or lever end, but eventually loses speed and needs a bleed at the lever. A good amount of air comes out of the lever, never any at the post.
    I've tried tightening the hose to 1X connection and making sure the speed port and bleed ports are tight but within a month or two the return speed is slow.
    Thoughts? How can air be seeping in without fluid leaking out?
    Figuring this all out as I go!
    Have you tried looking at the fitting at the post? I had a similar issue with mine when I first got it. It turned out that the issue was at the fitting at the bottom of the post. Replaced it and no issues since. Itís been two years with no problems.
    Oct 2014
    There is no leakage at either end of things which seems weird. If air is getting in it must be replacing fluid, but there is no trace of that.
    All of the air in my lines is at the 1X end, never any at the post end.
    If it goes to the point of replacing anything I'm calling Wolftooth for their sustain. That's how the Reverb should have come in the first place - I installed one of those on a friend's bike and it's been perfection, even in the cold.
  1. New and old reverb remote compatibility
    By brenrub in forum Components
    Last Post: 09-09-2016, 12:46 PM
  2. Reverb Remote Button Play
    By Skelldify in forum All Mountain
    Last Post: 01-11-2015, 09:00 AM
  3. Will 2014 Fox remote shock compatible with 2013 remote lever?
    By J0hnnie in forum Shocks and Suspension
    Last Post: 09-02-2013, 07:06 AM
  4. reverb remote question
    By b-kul in forum General Discussion
    Last Post: 08-15-2013, 06:22 PM
  5. Broke my reverb remote now what?
    By bmxking45 in forum All Mountain
    Last Post: 05-12-2011, 11:27 PM
Members who have read this thread: 16
