MTH 746 rear hub Wobbling cassette- Mtbr.com
Results 1 to 3 of 3
    Reputation: Makten's Avatar
    Feb 2014
    Got this rear hub on my new bike and when spinning the cassette, the largest sprocket is wobbling ~2 mm side to side. There is no play and I've taken it off and reassembled it with no difference. It's not the cassette itself, because I can see the whole thing going sideways, but of course it's most noticeable on the largest sprocket. Shifting still works, but it's not as good as should be.
    Does anyone know what could be causing the wobble? Don't want to send it away for warranty repair and be without my bike at the best part of season! I mean it still works, but this is not OK on a brand new hub.
    Rocks belong
    check the chrome end cap on the axle. my buddy's backed off, allowing for slop/play in the freehub itself
    I like 'em long, low, slack and playful
    Feb 2014
    Quote Originally Posted by 06HokieMTB View Post
    Thanks! I don't think that's the problem, because the bearings are overtightened if anything. I have a new Hope pro 4 hub that I could use, but... Would be nice fixing the current one first.
  1. Shimano cassette a bit loose on rear cassette hub
    By anymore in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-04-2018, 07:16 AM
  2. Rear hub/axle clicking noise + moving/wobbling around
    By ithacking in forum Wheels and Tires
    Last Post: 08-07-2014, 06:08 AM
  3. Avid SD7 levers...wobbling??
    By Bryank930 in forum Brake Time
    Last Post: 05-14-2013, 10:35 AM
  4. Wobbling cranks
    By agoura_biker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-30-2012, 10:16 PM
  5. Let you tell me about my rear wobbling wheel.
    By eurospek in forum All Mountain
    Last Post: 05-24-2011, 09:26 PM
