• 09-15-2010
    Bokchoicowboy
    MRX Comp cable replacement frustration!
    I love SRAMS simplistic user manual that says to pull out the old cable and then simply insert the new one.
    WHAT A BUNCH OF CRAP!
    The new cable will not just go in. It bends and frays before it gets into the shifter very far. I even used the old trick of supergluing the cable end to keep from fraying, but all the cable would do is bend, bend, bend. It would never come out.
    Rear side shifter. Daughter loves the grip shift, doesnt like trigger shifters. I am about ready to just tell her tough, she is not having these pieces of crap any more.
    F you SRAM!
    Anyone know of an easy way to change the cable, tell me now PLEASE!
  • 11-18-2014
    minourat
    Inserteing a Cable for a SRAM GRIPSHIFT Shifter
    I had this problem once. In that case I could insert the cable by bending the tip of the cable in the direction of the curve. Although the cable path changed the direction almost 90 degrees, I bent the cable tip only about 45 degrees.
