info on setting up a RS Lyric Solo Air- Mtbr.com
Results 1 to 3 of 3
    Hi folks,
    Can someone tell me where I can find info about setting up a Lyric Solo Air? I couldn't find it on the SRAM/RS site. It doesn't have a lot of adjustments, I just don't know where to even start as far as psi in the chambers go.
    -joel
    how about a d'oh! moment? looked at the fork and lo and behold, a guide based on weight.
    wuss
    Reputation: dropadrop's Avatar
    There are a few threads on the forum regarding setting one up. If you are not riding big drops the pressure chart might be a bit exagerated (I run quite a bit less).
    I recommend putting something on thr stachion to show how much travel you have used. Personally I find it hard to use the last 2cm. Start with low and high speed compression pretty much off and add some low speed compression to dial out brake dive. High speed compression affects sharper hits, not bottoming out.
