How to remove XX1 crank- Mtbr.com
Results 1 to 5 of 5
    mxh
    mxh is offline
    May 2015
    I'm trying to remove my XX1 crank so I can replace the PF30 BB (2015 model, if relevant)
    I've undone the 10mm bolt on the drive side and the drive side crank has come off OK.
    However, I can't pull the non-drive side crank off. I've tried tapping it with a rubber mallet, and undoing the BB adjuster (which is now loose) but to no avail.
    Is there anything else that I'm supposed to be doing - or is it just a case of hitting it harder? There's an 8mm bolt on the NDS, but it says 'Do not remove' on it. So I'm assuming that's not the answer!
    Reputation: Junersun's Avatar
    Jun 2014
    That's all I typically do to remove mine.
    Current Bikes
    2015 Transition Patrol AL
    2016 YT Tues AL
    2019 Kona Rove NRB DL
    2020 Banshee Paradox
    mxh
    mxh is offline
    May 2015
    Cheers - went at it a little bit harder and it eventually came out.
    Another question - once the cranks are back on, what's the procedure for setting the preload adjuster. I'm not sure whether I should be screwing it towards the frame as tight as I can by hand, or maybe doing that then backing it off a little. I'm assuming it's just to take up any side to side play, but I don't want to overtighten it and put sideways load on the bearings
    Jun 2014
    Sorry someone else will have to chime in on this. I don't have a preload adjuster. Mine are washer stack ups.
    Current Bikes
    2016 YT Tues AL
    After you've installed the crankset (10mm driveside bolt) to correct torque (48-54 Nm) the preload adjuster is screwed by hand until it just touches the bearing shield. It is just to take up side to side play as you described.
  1. Proper park Crank Puller tool needed to remove a Bontrager Crank Set
    By rockymtbiker in forum General Discussion
    Last Post: 06-14-2015, 03:34 PM
  2. Help! I screwed my crank up trying to remove it!
    By gobbledegoo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2014, 06:36 PM
  3. Remove Pugs crank arm
    By SpyGame in forum Fat bikes
    Last Post: 04-21-2013, 08:24 AM
  4. How Do I remove spider from XO crank?
    By MrEconomics in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-22-2012, 08:25 PM
  5. How to remove GXP crank
    By alanchan in forum Tooltime
    Last Post: 05-08-2011, 07:25 PM
