Help: XX1 crank seizes when torqued to specs- Mtbr.com
    I'm building an Ibis DV9 with 73mm BSA bottom bracket. Full DUB bottom bracket/crank XX1 eagle build kit. Spec'd and came with only the 4.5mm spacer for the drive side only, which is installed and correct per the SRAM pdf guide.
    After installing the bottom bracket and crank on the frame, one of the final steps is to turn the 8mm hex on the R crank arm to the recommended 54nm. But if I go beyond about 8nm then the crank/bearings begin to seize and the crank will not spin.
    Thanks in advance for the help!
    Reputation: Jetman46's Avatar
    Oct 2007
    Is the adjustment nut on the left side backed all the way off? That is how you preload the bearings.
    Should be really simple and straightforward install. Did a couple of Dub BSA installs myself.
    Like above, make sure the pre-load is backed all the way off and that there were no inner spacers on the cups (pretty sure that DV9 is a 73mm shell). BB should have come with the two 2.5mm spacers and the 4.5mm spacer (that goes on the outside of the BB).
    Quote Originally Posted by wfl3 View Post
    It was the two 2.5mm spacers on the BB which caused the problem. I trouble shot with Ibis and they helped me out A TON.
    Thank you both for your reply!
    Problem solved!
  1. Torqued my crank bolt, now this is happening . . .
    By chakotay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2015, 04:38 PM
  2. XTR cranks won't spin after being torqued
    By stryder508 in forum General Discussion
    Last Post: 04-28-2013, 03:21 PM
  3. Can I ride out my BB until it seizes
    By uh yeah in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-21-2012, 08:27 PM
  4. Truvativ Stylo Crank / BB Seizing When Torqued
    By surlyjackalope in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-05-2011, 11:56 AM
  5. Getting torqued
    By sangmatt in forum Tooltime
    Last Post: 06-24-2007, 07:43 AM
