GX Eagle Creaking- Mtbr.com
Results 1 to 3 of 3
    Reputation: Mad.Mtb's Avatar
    Aug 2014
    GX Eagle Creaking
    Anybody else having their Eagle derailleur creak? I have only about 100 mile on the bike and the creaking got pretty bad on my last ride. I thought it was the bottom bracket at first, but did some research online and found this video which is the same issue I'm having.
    I removed the hanger from the frame and found the hanger bolt had been over tightened and the derailleur mounting bolt was under tightened. Fixed that, cleaned up the derailleur and this seemed to minimize the creak. However, there still seems to be some residual creaking. Curious if anyone else is having this issue?
    The only trace I leave behind is tire marks.
    Dec 2016
    I had some creaking in my GX 1x11. It usually goes away if I remove the axle and retighten it to torque specs. Don't know why it happens but 90% of the time, that fixes it. The other 10% of the time, I fixed it by pulling the cassette and greasing all the contact points with the XD driver.
    Sep 2012
    It has been two seasons since I ran Sram stuff. But I had a similar creak with my last Sram RD (XO1 1x11). It was the clutch assembly. It is supposedly self-lubricating. My mechanic showed me the move to eliminated it. With the RD dropped to the small end of the cassette, meaning the RD cage is pulled all the way back parallel to the floor, move the whole cage from full back to full front, otherwise know as its full travel path fore and aft (careful, don't twist the cage or RD!). Repeat this 10-15 times and that sound should stop. Try it! See if that works for you. It did for me.
  1. best Drivetrain-- eagle or hybrid eagle?
    By SB Trails in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2017, 05:11 PM
  2. xo1 eagle cranks stronger then xx1 eagle cranks?
    Last Post: 06-30-2017, 10:07 PM
  3. SRAM Eagle chain with xx1 (non-eagle) chainring.
    By LyncStar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2017, 05:19 AM
  4. Federal Government / Bald Eagle and Golden Eagle death proposal.
    By DIRTJUNKIE in forum Off Camber (off topic)
    Last Post: 07-05-2016, 08:14 AM
  5. RockShox Ride Experience at Eagle Bike Park in Eagle, Idaho
    By lil29er in forum Idaho, Montana, Wyoming
    Last Post: 06-28-2012, 04:56 AM
Members who have read this thread: 12
