Guide ultimate bleed block?- Mtbr.com
    Jun 2014
    Anyone know where I can find a bleed block for the new guide ultimate? Cant seem to find one online anywhere, cant even find a part number off the sram website...
    Looks like this according to the manual
    Also shown here
    https://youtu.be/it9F2gvju_Y?t=16s
    Did you order the Ultimates as an aftermarket kit? I've installed two sets on customers' bikes, and the bleed blocks did not show up in the kits. The pad spacing is unique, so you can't just retrofit another block, according to SRAM. When I called SRAM HQ to get the blocks sent, it seemed like I had found a hole in their system, because they had to send a full bleed kit that just happened to also include the bleed blocks. They may have fixed that by now, but just call in and ask them to send you the correct Ultimate block.
    Jun 2014
    Quote Originally Posted by JHCreighton View Post
    Do you have a picture of the bleed block they sent you?
    I ordered this kit online and I am hoping the one in it will work with it
    https://www.bike24.com/1.php?content...=1000,2,15,117
    and yes I ordered the F+R as a kit online. It came with everything BUT the bleed block
    SRAM Guide Ultimate Discbrake Set grey | Disc Brake - Sets Shop
    The block looks just as pictured in your previous diagram, except it is red. Most of the kit you ordered looks likes the one I was sent, however, the picture does not include the correct bleed block. In the product details, it says the kit includes "each 1 bleed blocks for all Guide, XX und X0 brakes," but, then again, the Guide and Guide Ultimate bleed blocks are not pictured. I would assume that since the kit includes the Bleeding Edge tool, that it would also have the correct bleed block, but that is being hopeful. Go through your LBS to get the appropriate block sent to you for free if the kit does not have one.
    The brakes are awesome and worth all the hassle.
  1. Guide ultimate bleed block??
    By mattwright999 in forum Brake Time
    Last Post: 10-24-2015, 11:47 AM
  2. Guide Ultimate Bleed Kit?
    By bogeydog in forum Brake Time
    Last Post: 10-22-2015, 12:37 AM
  3. Makeshift Magura Bleed Block?
    By apache in forum Brake Time
    Last Post: 02-26-2015, 10:23 AM
  4. Avid bleed question(bleed block)
    By Kawigreen99 in forum Brake Time
    Last Post: 02-29-2012, 05:33 PM
  5. Hope bleed block?
    By 007 in forum Brake Time
    Last Post: 09-21-2011, 08:38 AM
