Guide RSC w/ Connectamajig help!!!- Mtbr.com
Results 1 to 3 of 3
    CAMBr Trail Crew
    Reputation: DDDonny's Avatar
    The Guide RSC rear brake on my 2015 Sight came equipped with a connectamajig. I need to replace by hydraulic cable, but SRAM (with all their "infinite" wisdom!) does not manufacture a replacement connectamajig hose for the brakes and the reverb hose is incompatible! My problem now is I'm unable to find a wrench/spanner that is narrow enough to fit between the connectamajig and the Guide's banjo to get the stupid thing off! If anyone has dealt with this I'd appreciate some solutions...
    Total PITA!!!
    It's carbon dontcha know.
    Reputation: 6thElement's Avatar
    Take the brake off the bike and use mole grips.
    Rolling on 29", 650b, 8.3" and 23mm
    CAMBr Trail Crew
    I purchased a Park Tool CBW-1 8mm x 10nm wrench thinking it would be narrow enough to get the ****er off... Nope! I ended-up going to my LBS where they grinded off some metal on the 8mm side. Then, and only then, was I able to get the POS connectamajig off...!
  1. Replies: 1
    Last Post: 05-11-2016, 10:45 AM
  2. Replies: 0
    Last Post: 04-08-2016, 12:05 PM
  3. Replies: 12
    Last Post: 01-05-2016, 02:10 PM
  4. Reverb stealth connectamajig
    By expatrider in forum All Mountain
    Last Post: 07-20-2014, 05:39 PM
  5. Reverb Connectamajig on a Mach 6
    By trickbooter in forum Pivot Cycles
    Last Post: 05-26-2014, 12:00 PM
Members who have read this thread: 7
