Guide R to RS/C
Printable View
  • 02-14-2019
    The_Bob
    Guide R to RS/C
    Hi all
    Just want to know whether one could convert Guide R to Guide RS or RSC by fitting the appropriate lever kits. As per the product below:
    https://www.ebay.com/itm/SRAM-Guide-....c100008.m2219
  • 02-14-2019
    mtnbikej
    Originally Posted by The_Bob View Post
    Hi all
    Don't think you can go to the RSC as the master cylinder doesn't have the provision for the Contact Dial Wheel.
    https://www.sram.com/sites/default/f...spc_revd_0.pdf
  • 02-17-2019
    e-luder
    The main piston is different from a R to an RS so swapping the levers wont do it.
    You will need an entire master cylinder to upgrade to RSC's.
  • 06-18-2019
    The_Bob
    Swapped out the lever/master cylinders from R to RS and it is working great. Was initially a bit bummed with the feel compared to the R, but I have hence followed Henry's brake hacks video on GMBN and am loving the Guide RS now
