Guide brakes, sticky caliper Pistons- Mtbr.com
Results 1 to 3 of 3
    Reputation: jdcatnau's Avatar
    Feb 2007
    I just bleed my Guide RS brakes and noticed that the Pistons did not evenly extend. So I took the pads out and stroked the lever then pushed the Pistons back into the caliper for a few times and they still are not balanced. I was thinking of trying the pit stop grease when I rebuild the caliper. Is this a good idea? Any input would be greatly appreciated.
    Reputation: bigkat273's Avatar
    This is why I switched out to Shimano brakes. You can try splitting the calipers then pull the pistons and clean/lube the seals with dot fluid. If that fails a new piston/seal kit is your last resort.
    They will never just extend evenly. Even a minute amount of friction difference will allow one piston to extend first. With the pads installed, and a good bleed (no air in the caliper), everything will be fine.
    Side note: Most "sticky" pistons are a result of air behind the piston, not a need for lube on the piston seals.
  1. XTR 975 Front Caliper Pistons Off Center
    By egebhardt in forum Brake Time
    Last Post: 06-16-2015, 03:55 PM
  2. Replies: 1
    Last Post: 10-04-2014, 10:09 PM
  3. Sticky caliper
    By Spencerespencer in forum 29er Components
    Last Post: 06-15-2014, 08:46 PM
  4. Can't get caliper pistons to retract on Elixir CR!
    By onepivot in forum Brake Time
    Last Post: 05-14-2014, 07:36 PM
  5. Lubricating pistons in a Marta SL caliper
    By BrettM11 in forum Brake Time
    Last Post: 12-14-2011, 06:42 AM
Members who have read this thread: 4
