Grip Shift and Hammerschmidt?- Mtbr.com
Results 1 to 3 of 3
    Reputation: OldHouseMan's Avatar
    I found 2 threads specifically talking about this combo and both were from the same guy, looks like it worked for him. Anybody else doing this?
    And...Any chance Sram will make or has in the works a grip shifter compatible with Hammerschmidt?
    STS
    STS is offline
    Reputation: STS's Avatar
    every front shifter will work with the HS
    the cable pulled is the same than the needed to change between two chainrings
    you just loose 1 click
    You found my threads. Two of the guys I ride with also run Hammerschmidt with grip shift setups without any issues. Just have to make sure you fully pull and release the cable between shifts.
