Force 1 Crank Boots?- Mtbr.com
Results 1 to 3 of 3
    Jul 2015
    Does anybody know if the SRAM XX1 crank boots fit the Force 1 carbon cranks? Or if any of the other brands fit?
    I've got the Force 1 carbon cranks on my gravel bike, and I already have some damage from rock strikes on the first ride.
    Santa Cruz Tallboy 2
    Cannondale CAAD12
    Niner RLT9
    Salsa Fargo
    Niner SIR9 27.5+
    Surly Krampus
    Jul 2015
    Just to follow up in case it helps somebody in the future, I tried the Raceface and SRAM boots. Both work, but the Raceface require a little widening of the holes for access. Easy enough with a dremel tool. SRAM work without modification. So if you want colors, go Raceface. Black... go SRAM.
    Sent from my XT1030 using Tapatalk
    Cannondale CAAD12
    Niner RLT9
    Salsa Fargo
    Niner SIR9 27.5+
    Surly Krampus
    Aug 2015
    Good job!
    Quote Originally Posted by AVLthumper View Post
    Thanks for answering your own question - this helped me out. I'm in the same situation with my gravel bike. Cheers!
  1. crank boots
    By guvna in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-14-2018, 12:28 AM
  2. Spank Spikes and Crank Boots
    By IPunchCholla in forum Components
    Last Post: 06-15-2017, 05:22 PM
  3. Sram Force CX1 Crank or make single ring from double Crank
    By prof.einstein in forum Cyclocross
    Last Post: 12-28-2015, 01:20 PM
  4. Replies: 28
    Last Post: 02-02-2015, 09:24 PM
  5. Weighed: Crankskins.com crank boots
    By westin in forum Weight Weenies
    Last Post: 06-04-2012, 09:22 AM
