crank: 2010 XX v 2011 X.0- Mtbr.com
Results 1 to 11 of 11
    Nov 2006
    i'm thinking of upgrading the drivetrain to 2x9 soon...
    wondering whether to go ahead with the XX cranks or wait for the X.0 ones? when will 2011 X.0 be available? and what's the expected pricing of the X.0 crankset? XX is currently $430.
    thoughts on this setup?
    XX cranks 26-39T + GXP Team bb
    X.0 gripshift
    XT front der
    X.0 med cage rear der
    XT 32-11T cassette
    XTR chain (better shifting with SRAM?)
    wheelworld has '10 XX 28x42 GXP for $339.99 right now! just got mine from the ups man a few days ago. it was boxxed up and in perfect condition. for that price, why wouldn't you?
    You will likely need a 10 speed chain if you are using 10 speed cranks. It'll work fine on the 9 speed cassette and derailleur. A 9 speed chain will try to shift up to the big ring when you cross chain from the small ring and the 12 or 11 T cog. Atleats, this is my experience.
    Nov 2006
    Quote Originally Posted by nkdraygun
    they only have the 42-28T in stock. i want the 39-26T combo. wonder if pricepoint will match wheelworld?
    Nov 2006
    Quote Originally Posted by kdiddy
    will a 10-speed chain work on a 9-speed cassette?
    Freedom Isn't Free
    Reputation: A-Hol's Avatar
    Dec 2005
    Are you worried about Q-factor? XX has mutliple Q factors including the narrow 156 mm and X.0 runs standard Q-factor. I noticed the difference between my narrow road bike and wide mtb until I switched to XX 156 mm. Of course, you bike will need to support the 156 mm Q factor if that's what you want.
    10 speed chain will work fine on 9 speed cassette.
    Reputation: amillmtb's Avatar
    Jun 2005
    Quote Originally Posted by dypeterc
    Yes. I will be doing this soon with an XX crank.
    Nov 2006
    Quote Originally Posted by A-Hol
    i guess it might be worth doing some measurements to see if i can run a 156Q. btw, i'm throwing this on a '91 c'dale F3000.
    Reputation: DavidR1's Avatar
    Anybody had a problem using the X0 grip shift with the XX cranks and XT derailleur? This is what I plan to do as well and want to make sure it will work.
    CyclingCentralVa.org
    Cuánto pesa?
    Reputation: Jake Pay's Avatar
    My frankenstein 2x9 drivetrain:
    Front dérailleur...XX
    Rear dérailleur...08' XO
    Shifters...XO grippers
    Cassette...XC-999 (11x32)
    Chain...KMC X-10SL
    Crank arms...RaceFace NEXT
    Chainrings...ExtarLite Gara (42x28)
    Bottom bracket...970 XTR
    Cables...NOKON
    This set-up has been real good to me.....
    Jun 2005
    Quote Originally Posted by DavidR1
    I'll be able to tell you on Thursday, that's when my rings should be in!
    My set up will be
    X.0 rear derailleur
    SLX front derailleur
    X.0 grippers
    Cannondale Hollowgram Si SL with XX spider
    Sram XX 26-39 rings
    KMC chain
