• 03-22-2020
    NRP
    Code vs Guide hose connections
    Thinking about upgrading the brakes on my Kona Process to Guide RSCs or Code RSCs (currently it has Guide R).
    Anyone know if the brake hose connections are the same between Guides and Codes? I'd like to reuse the existing hoses if possible.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  • 03-25-2020
    bigb73
    The Guide caliper has a different fitting than the Code caliper. Levers use the same fittings. Sram Code Hose #00.5016.168.170
  • 03-25-2020
    NRP
