which button mount is correct for reverb on 1 x 10 setup- Mtbr.com
Results 1 to 3 of 3
    I've switched my bike to 1x10 and would like to run the reverb control beneath the left brake lever where the front shifter used to be. I will be ordering my new post online so I would like to know which variation of the RS reverb would work best with my setup.
    Which setups have you all tried?
    There's always next year.
    Reputation: padrefan1982's Avatar
    Mar 2005
    I run the exact same set up as you're describing. You want to order a Reverb with a right hand remote. When you flip it, it will sit under the brake on the left side.
    Depending on your brakes, you might need to play with set up to get everything to play to your satisfaction.
    It's been a while since I checked this thread. Thanks for the info, Padrefan!
  1. Reverb Remote Button Play
    By Skelldify in forum All Mountain
    Last Post: 01-11-2015, 09:00 AM
  2. XT lever/Reverb button compatibility?
    By Stu McGroo in forum Brake Time
    Last Post: 08-03-2012, 06:45 AM
  3. Correct frame post mount adaptor to use?
    By GpzGuy in forum Brake Time
    Last Post: 06-29-2011, 12:28 AM
  4. Post mount to IS mount adapter...correct me if I'm wrong.
    By ProjectDan35 in forum Shocks and Suspension
    Last Post: 04-22-2011, 08:38 AM
  5. Correct derailleurs and cassette for my setup
    By Gat0rvean in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-14-2011, 09:45 AM
