B1 stealth reverb sag after rebuild....- Mtbr.com
Results 1 to 7 of 7
    Have succesfully rebuilt A1 external and stealths several times , but my b1 stealth is giving us troubles. 9 month old , lube and new keys and oil and all went smooth. Post was rock solid but only untill we lowered it for the first time. It immediately developed aprox 5mm of sag.It does not feel like ďairĒ sag, post can be depressed aprox 5mm and then a hard stop. What did we do wrong ?
    Reputation: PurpleMtnSlayer's Avatar
    Jun 2015
    I could have written your post myself. Same past experience and current issue. Did you find the fix for the 5mm sag?
    No , have not really tried though. But guess its time for another rebuild/internal lube job soon. To tell the truth ; i dont really notice it anymore when on the bike. Will update when i have taken it apart again.
    Jun 2015
    Ya itís really not that bad. But you know how it is. Looking at these new longer droppers and thinking I got to have one. I donít, especially cuz I can add 10mm of usable drop if I get this slop out of my reverb.
    Did some more research. Apparently the ifp seal is good in one direction and bad in the other. Specifically lifting the bike from the seat with the post down allows air past the seal and into the oil. So we just need to bleed the ifp to get that trapped air out. I just did the 200 hr service, hoping that would fix it. It didnít. So I have an ifp height tool, soft jaw shaft clamps, and some reverb fluid on the way. Iíll let you know if I can get the slop off the top.
    Jul 2018
    Is the B1 the version that has Gold lettering near the seat?
    Jun 2015
    Yea
    Jul 2018
    The B1 rebuild process is different to the A1 and A2 instructions so make sure you follow the right guide. I've rebuilt a fair few and managed to get them rock solid so it can be done.
    Sent from my LG-H870 using Tapatalk
  1. Replies: 6
    Last Post: 08-03-2017, 04:19 PM
  2. Replies: 0
    Last Post: 11-13-2015, 02:41 PM
  3. Reverb will not compress after rebuild
    By jaspermountainman in forum Components
    Last Post: 09-19-2015, 06:04 PM
  4. To Stealth or not to Stealth?
    By CuddlyToast in forum SRAM
    Last Post: 12-26-2013, 01:12 PM
  5. Rock Shox Reverb / Reverb Stealth
    By WorldIRC in forum Trek
    Last Post: 07-01-2013, 07:12 PM
