AXS Eagle gears and battery life on Garmin- Mtbr.com
Results 1 to 10 of 10
    May 2017
    I just figured out that I can have both the battery life and which gear I am in showing on my Garmin from the AXS. I use a Garmin 520.
    Jul 2019
    Quote Originally Posted by careyj1 View Post
    You can also set up the axs app and it will give you a ride report with total shifts during the ride and some other neat stuff.
    Sent from my SM-N975U using Tapatalk
    May 2017
    Quote Originally Posted by derekmcelwee View Post
    Thanks, I had that setup but did not look at it until now. 581 shifts and it shows the time in each gear or miles in each gear. Very cool.
    Do you know if the SRAM Q crank powermeter will work with AXS Eagle setup without replacing anything but the spider?
    Jul 2019
    You can't add the quarq spider to the sram direct mount crank. The quarq uses an 8 bolt mount and the regular crank uses a 3 bolt mount. You have to unfortunately but a new crankset. And the quarq power meter doesn't have any functionality in the axs app. It shows up but doesn't do anything
    May 2017
    I was hoping it was 8 bolt but I didn't assemble the AXS Eagle.
    Thank you!!
    How do you go about doing this?
    Jul 2019
    Quote Originally Posted by Ordinarybikes View Post
    Add the axs as a sensor
    Do you know if it will work on the Edge 130?
    May 2017
    1) put the Sram AXS app on your phone
    2) Connect Pair the AXS system to your Sram AXS app
    3)On your Garmin unit go into activity profiles then data screen then select Add battery and gears to your Garmin head unit. This is the area where you decide the data you would like to see on the Garmin unit as you ride. (Example heart rate, time of ride, Elevation, battery life, gears, miles, etc
    4) On your Garmin unit go into settings then Sensors and add your Sram AXS.
    When I took this picture the bike wasn't near the Garmin unit so the gears show 0/0 verses 1/12 or whichever gear that I am in. Also it doesn't show the battery amount for the same reason.
    Attached Thumbnails Attached Thumbnails AXS Eagle gears and battery life on Garmin-garminunit.jpg
    Feb 2007
  1. Quarq DZero Powermeter XX1 Eagle BB30 crank on SRAM XX1 Eagle AXS DUB spindle?
    By dommelsch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2020, 09:26 PM
  2. My life with XTR 12 speed and SRAM XX1 Etap AXS
    By the mayor in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-25-2019, 11:23 PM
  3. Replies: 9
    Last Post: 07-06-2019, 09:54 AM
  4. Eagle XX1 AXS XG-1299 cassette and chain
    By farfromovin in forum Classifieds
    Last Post: 05-08-2019, 03:34 PM
  5. Gears, Gears, and More Gears
    By OneEyeMan in forum Singlespeed
    Last Post: 09-05-2006, 06:38 PM
Members who have read this thread: 22
