avid elixir R SL caliper rebuild question- Mtbr.com
Results 1 to 3 of 3
    wannabee
    Reputation: giantbikeboy's Avatar
    Dec 2004
    should I use any lubrication on the piston seal? it fits inside the body of the caliper and around the outside of the piston. use brake fluid? use a light grease? use nothing. these brakes have never worked right. the inboard pad will not retract away from the rotor. bleed after bleed and it operates the same. I searched here and the SRAM site and found nothing. a link to a parts list would be helpful. I only have one rebuild kit, no part number on it. thanks.
    Reputation: Redlands R&C's Avatar
    Dec 2013
    Not sure if you ever figured this out, but I use the Avid DOT grease, a light coating, on the piston seals. Works well in my experiences
    wannabee
    Dec 2004
    I went to the LBS and the mechanic gave me some orange colored DOT grease. not sure if it was AVID or not but it did the trick. thanks!
  1. Avid Elixir 1 Up Front - Avid Elixir 5 On Back(?)
    By jdaviped in forum Brake Time
    Last Post: 04-14-2014, 11:47 AM
  2. Replies: 6
    Last Post: 09-06-2012, 05:56 PM
  3. Replies: 2
    Last Post: 07-22-2012, 10:52 PM
  4. xx caliper vs elixir caliper
    By slimat99 in forum Weight Weenies
    Last Post: 05-22-2011, 09:06 AM
  5. Avid : from Elixir RSL to Elixir X0,is it worth it ??
    By Devastazione in forum Brake Time
    Last Post: 05-06-2011, 05:12 AM
