Avid Elixir CR 2009 blade replacement- Mtbr.com
Results 1 to 2 of 2
    I've tried the Brake Forum but have not got response. Inpatients got the best of me so I'm trying here.
    I broke my Carbon blade and replacing w/ more reliable alum blade. Where can i find a manual in regards for blade replacement? Or can someone kind of enough to write an instruction on "how to" replace the blade?
    thanks in advance if I don't reply!!!!
    Reputation: daniyarm's Avatar
    You can order them from Universal Cycles, looks like they have them in stock.
    As far as instructions... If they don't come with some you can always call SRAM and have their tech guys pull up technical docs and walk you through it. They have always been helpfull for me. But I think there is only 1 hex screw that holds it in place.
    I think once you receive the kit, it will be easy to figure out which screw to take out. Good luck.
