2012 DP Revelation not returning to sag postion problem ?- Mtbr.com
Results 1 to 2 of 2
    jddist
    Anyone experience the following similar issues as I am having with my dual position solo air 2012 revelation? It is butter smooth so not a stiction problem. During rides, once it gets compressed to say around 50 to 80%, like when coming down a tech section, it wont come back up to the normal sag level (%30 in my case) but stays stuck down around %50 sag until all weight has been taken off of it. Even if I ride around no handed it still does not return to proper sag. I don't have to stop and physically pull it up, but I have to ride like and extended wheelie or lean way back to take all weight off of the fork. Its almost like it is loosing air but when I check the pressures, even after a number of rides there is no real loss of pressure. I am almost thinking it is something like air transferring from the positive to the neg side. I recently did a full service to it and that did not solve the problem. Any idea or suggestions?
    Thanks a bunch.
    Feb 2017
    Concerning RS Rev. XX
    Quote Originally Posted by istvisinet View Post
    Thanks a bunch.
    Hello
    Did you solve your problem? I have got the same problem with My fork recently.
    Best regards, Mats
  1. Rockshox Revelation XX 2012
    By hezishohat in forum Shocks and Suspension
    Last Post: 02-04-2013, 04:52 AM
  2. 2012 Revelation RL
    By Neo-ST in forum Shocks and Suspension
    Last Post: 04-21-2012, 01:46 PM
  3. rockshox revelation dual position problem
    By akiracornell in forum All Mountain
    Last Post: 03-02-2012, 06:28 AM
  4. 2012 Revelation
    By OldHouseMan in forum SRAM
    Last Post: 12-08-2011, 10:34 PM
  5. Older Revelation Problem
    By Lexicon in forum Shocks and Suspension
    Last Post: 03-25-2011, 06:41 AM
